5.0 MPI-Parallelization with NGSolve
  • How do we start a distributed computation
    • mpirun/mpiexec
    • batch systems
    • jupyter-magic
  • Basics of MPI-parallel NGSolve
    • distrubuted meshes
    • distributed Finite Element Spaces
    • distributed Linear Algebra
    • solvers & preconditioners
MPI - Message Passing Interface
Within an MPI job, each process in a computation is given a "rank", a numer from \(0\ldots n_p\), which is used as it’s identifier.
Communication happens within so-called 'mpi-communicators', which are contexts within which messages can be exchanged.
Running computations with MPI
Directly - mpiexec
We ask you not to do this if you use the cluster (it will run the computation on the login node!)
Jupyter-Magic
Download those and call
How to use it
We can start a "cluster" of python-processes. The cluster will be identified by some "user_id". While it is running, it will allocate N cores (in this case 5), to this specific cluster.
num_procs = '5'
start_cluster(num_procs)
connect_cluster()
%%px --targets 3:5
stop_cluster()
Please clean up your clusters!
Batch System
** sbatch slurm_file **
The Rest of the talk:
  • Basics: Distributed Meshes, Finite Element Spcaces and Lienar Algebra
